in regard to the drawbar. Take a 460 / 560 with a fast hitch for example. There is the drawbar which is essentially two prongs attached by a bar in between with holes in it. All of the pull load is directed through the prongs and the bail, etc up to the mounting point. There is also the swinging draw bar that most FH tractors today don't have anymore. A standard draw bar that attaches in a pin hole in the bail just rear of the forward pivot. It straddles the drawbar mentioned at the beginning of this paragraph.
You can purchase adapters that lock into the receivers of the FH and add a bracket to the rock shaft to mount the top link. It works "OK". FH equipment isn't the easiest thing in the world to find and you aren't going to buy any new equipment that mounts via fast hitch.
