Re: Farmall H rearend
Posted by neblinc on March 20, 2008 at 08:47:18 from (76.79.15.58):
In Reply to: Farmall H rearend posted by Andrew Anderson on March 19, 2008 at 16:56:08:
NBAllen said: (quoted from post at 11:31:31 03/20/08 Randy,
I meant to ask this earlier.
How did/do the o-rings hold up with the sharp edge of the lock washer?
How effective is the lock washer with the o-ring to bite into?
Nathaniel
I guess I should take one out and see if it was damaged or not. I tried to use a size that would fit tight in the hole, so hopefully the washer just pushed them in. Got the large assortment set at HF on sale.
Randy
