Re: new F12 owner questions
Posted by Farmallgray on March 20, 2008 at 11:28:52 from (208.254.241.76):
In Reply to: Re: new F12 owner questions posted by John M on March 19, 2008 at 13:50:53:
This is the second time this week I have heard someone say that the F-12s had the SN stamped on the frame rail. I have never seen one this way. But I would like to see a photo if it is true.
The F-12s did not have casting date codes other than on the hydraulic lift assemblies so he won"t be able to tell that way. If the engine has been swapped then the front tank support has probably been removed or changed. So I would say you are pretty much out of luck on determining the year of it.
