Re: Help with IH 350 Hyd.
Posted by Janicholson on March 20, 2008 at 13:26:28 from (199.17.6.122):
In Reply to: Help with IH 350 Hyd. posted by Greasy John on March 20, 2008 at 08:25:05:
A 350 Farmall (not Utility) will be equipped with three control valves on the tight side of the dash. One of the valves is being used for the Fast hitch. The other two are ready for your use. They may be connected to hoses for implements (remotes) or they may be unused. The valves have controls on their non handle end allowing three positions (roll pin under a sheet metal spring clip, on a flat sided knob) the position of this knob sets Full double acting, single acting, or full float single acting. Double acting is CCW (if I remember correctly).
If these valves are missing, they are common IH valves from that era used on the IH line. Good luck. JimN
