Re: 230 hydraulic problems
Posted by Hugh MacKay on March 20, 2008 at 19:06:16 from (209.226.247.151):
In Reply to: Re: 230 hydraulic problems posted by dozinhal on March 20, 2008 at 18:21:58:
Hal: You can't expect clamped hoses to withstand the high pressures of a hydraulic system. When new the lines from pump to controls on a 230 would have been heavy wall steel pipe. Hose is not even recommended. You need replacement steel lines.
