Posted by Jake Winn on March 20, 2008 at 21:09:19 from (207.200.116.7):
In Reply to: stuck H engine posted by Narrowfarm on March 20, 2008 at 18:00:55:
If its stuck that bad the head needs to come off anyway. I had one engine that was lightly stuck but broke free by turning it backwards, then with oil in the cylinders, it rolled all the way over. I pulled the heads anyway to be safe and Im glad I did. THey will filled with mice nests and surface rust.
I have had good lucking pulling the head, cleaning around the top of the piston and cylinder with a wire wheel, then using high pressure air, blowing all the debris out from around the piston to the bore. Then i put Coke Classic in there and let it sit for a while. Every now and then tap on the pistons with a oak block and a 4lb hammer or so. This will help shake it and help the Coke work its way in. The key to any of this is patience. I have had good luck with PB Blaster and ATF as well, but like i said, patience is the main thing. Good luck
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
