Farmall Tractors Discussion Board
Re: farmall 560 illisrations?
Posted by Woody on December 16, 1998 at 12:44:23:
In Reply to: farmall 560 illisrations? posted by Chuck on December 15, 1998 at 19:01:15:
First response was a bit light, but accurate. To my knowledge, all you have to do is take everything from the fast hitch off. Then replace with the three point. Question for the 'Group': once the fast hitch is off, is the 'standard' four swivel bolt with bolsters there just as if it never had a fast hitch? I've only switched from the standard draw bar set-up (H's and M's)...?? If the four swivles are there, the three point will match up and bolt in place. Attach a single or double action cylinder (your preferrence) in the logical place (do you have a three point kit with dual cylinders? If so, you'll need to split the inlet and outlet [dual acting cylinder(s)]). If the swivles and bolsters are there, even I can do it!!!
Post a Followup
: Re: Re: farmall 560 illisrations?
