Re: 826, 358 German - Coolant in the oil
Posted by daniel henebry on March 21, 2008 at 10:07:19 from (12.147.63.126):
In Reply to: 826, 358 German - Coolant in the oil posted by Kofa 2 on March 21, 2008 at 09:17:32:
The tractor vet is correct you will need to overhaul the motor. I would suggest having the block checked to be sure that the bottom is not eroded from the corrosion from the antifreeze. Hopefully the problem is in the sleeves. The will get pin holes in them. For people that do not have water filters on their tractors they need to keep their antifreeze changed and add an antifreeze conditioner such as DC4 to prevent the problem. You can monitor the water conditioner with a simple test kit that are available thru your big truck dealers on whether you need to add more conditioner.
