Re: 706 heater lines
Posted by Owen Aaland on March 21, 2008 at 12:40:17 from (65.161.86.122):
In Reply to: 706 heater lines posted by Doug-Iowa on March 21, 2008 at 09:41:35:
The water pump fitting IS the return. Coolant is drawn from the bottom of the radiator and pushed into the block.
You will need to put a tee fitting in the head where the temperature gauge is and take the coolant from there to the cab heater. Best to put a block heater in one of the frost plug holes instead of the external tank heater. Pluming a tank heater in the same loop as the cab heater can reduce the effectiveness of both.
