Posted by John T on March 21, 2008 at 14:47:13 from (66.244.97.31):
In Reply to: H not charging posted by Jim Rohde on March 21, 2008 at 09:41:35:
Jim, Neb was kind enough to post my entire procedure below, butttttttt Im puzzled it needs polarized so often?? Whether or not the battery is in place or not shouldnt make any difference cuz if the cutout relay opens as it should on shutdown its NOT connected to the battery anyway (or battery will rapidly discharge) PLUS its the residual magnetism in the soft iron field poles that retains magnetism in the first place???
Although it takes some time, working through my procedure in its Para 5 will easily tell if non charging is a Genny versus a VR problem but do as posted first n check easy simple things FIRST like a good ground on BOTH the Genny and VR and a good n tight belt then work from there. Also theres gotta be hot battery voltage present at allllllll times on the VR's BAT terminal ya know.
Bob M also has more of a flow chart type troubleshooting procedure if that works better for you
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
