Re: Serial number information.
Posted by Hugh MacKay on March 22, 2008 at 02:45:33 from (216.208.58.157):
In Reply to: Serial number information. posted by Dodge Man on March 21, 2008 at 19:35:45:
Dodge Man: Go to serial number on left of this page, click on it, then click on International and Farmall, then I-140 and F-140. You can see for yourself.
All 140s between serial number 26801 and 45000 came from the factory as 12 volt with a generator. It was also negative ground.
