Re: Allan In NE, Rear Hydraulic Remote ???
Posted by Allan In NE on March 22, 2008 at 07:20:04 from (148.78.243.26):
In Reply to: Allan In NE, Rear Hydraulic Remote ??? posted by gots-2-go on March 22, 2008 at 07:08:54:
You betcha!
If it is any good (doesn't leak), it will work just fine and will be a simpler installation too; ya won't have to build a bracket to install. Just drill a couple of holes to bolt 'er on.
You will of course have to use the John Deere hose ends with that head. Yes, those connectors at the block are standard and can be bought at any hydraulic outlet store.
The reason I used the 66 series block was to stay constant with all my various equipment's hose ends. Wanted 'em all the same.
Allan
third party image
