Re: Allan In NE, Rear Hydraulic Remote ???
Posted by Heat Houser on March 22, 2008 at 10:37:07 from (69.66.35.73):
In Reply to: Re: Allan In NE, Rear Hydraulic Remote ??? posted by rustyfarmall on March 22, 2008 at 08:33:39:
The thread JD used was SAE o-ring boss. (ORB, SAE J514) It was not a unique JD thread. Any hydraulic fitting store can match.
If you only look at the thread diameter and pitch, the threads on a JIC 37 deg flare,(SAE J514 37) and SAE o-ring boss are the same. ORS, o-ring face seal, is a bit larger on the thread diameter.
There are many ISO threads out there such as DIN,(German) JIS,(Japanese) BSP,(British) and GAZ (French)
