Re: Is this wrong
Posted by Janicholson on March 22, 2008 at 13:24:25 from (199.17.6.122):
In Reply to: Is this wrong posted by Vito on March 22, 2008 at 13:06:34:
Yes it is wrong. But understandable!!!
All three connections on the H are hooked up to the same port on the pump. The left rear is designed to have a restrictor in it to limit the response of a trailing implement cylinder, but (I think)it needs a restrictor in the elbo to do that. There is no way to get multiple supply from the different ports. When connected to a two way valve, the valve goes to open center and thus dumps all pressure. Connect a second (or third) valve to the system such that the return (exhaust) from one feeds the intake of the next. Do not use two valves at once, or unpredictable motion happens with this setup. A open center dual valve system will be setup this way. JimN
