Yea, Pull the tractor back apart and remove the ppa from the flywheel lay the ppa on the floor and get three 1/4 inch nuts, Use your heel and press each release lever down place the nut between the lever and the pressure plate cove to hold the leveres down after ya got that done then place the pressure plate on the pto drive then place the clutch disc on the transmission shaft now carefully slide the tractor back together and wiggle it together DO not pull it together with the frame bolts you can use the frame bolts to HOLD it while ya wiggle and snug it with your fingers when it with in lets say a 1/4 inch of being together then go ahead and tighten them up Then you go up thru the bottom and start bolting the pressure plate to the flywheel . Just make sure that the nuts fall out from behind the fingers .
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
