Re: I need some wiring help
Posted by Farmer Bob on March 22, 2008 at 21:03:54 from (71.50.2.37):
In Reply to: Re: I need some wiring help posted by Janicholson on March 22, 2008 at 20:39:12:
I would only like to add that the wire from the push/pull or on/off switch going to the coil should be attached to the "Neg" (-) terminal of the coil. Then run a short 12 gauge wire from the "Pos" (+) terminal of the coil to the post with a washer and nut on your distributor.
