1941 Farmall H starter
Posted by Mark Wiggins on March 23, 2008 at 06:16:02 from (12.77.55.56):
Is there a specific procedure for removal and installation of the starter? I need to remove it to see if there is anything preventing it from turning. I heard a "POP" then there was nothing. I put the meter to the stud that the cable connects to and there was 6.45 volts. I did not have a third hand to see what happened when the start switch was pressed. I am assuming there is a broken conductor of some sort inside.
THANKS!
Mark
