Re: Will a selective lift control unit
Posted by Vito on March 23, 2008 at 10:05:07 from (24.177.4.206):
In Reply to: Will a selective lift control unit posted by Vito on March 22, 2008 at 19:15:38:
M,
Yes ,I understand I can't run both at the same time but what I am trying to do is be able to shut one off and the other on from the drivers platform area.
To answer your questions:
1951 Farmall H
One way loader
2 way remote set up
Thank you for your help.
Today's Featured Article - Tire Fluids - by Curtis von Fange. It came as a surprise. The tire on the tractor needed to be pulled off to get to the brakes for service. The tires were blocked, the rear end raised on jacks, the lugs loosened and the tire loosened from the hub. Then, as the big lugged circle of rubber slipped off the last wheel stud it became apparent that there was more there than just an empty tire. Four hundred pounds of rim, tire, and fluid dropped to the ground like a sack of wet cement. Fortunately the installer jumped out of the wa ... [Read Article]
