450 ta is it worth it
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by R Rahmier on March 05, 2000 at 18:01:37 from (207.150.158.139):
I started tearing down the old 450 today the ta overriding clutch rollers were worn flat the inside race they roll on is extremly rough and the ramp has slight wear I dont know if I should chance putting just the rollers and the pins and springs that put tension on them in or by a new ta also the bearing by the pinion gear was out and the flywheel has hairline cracks in it should I get it refaced?
Post A Followup
: Re: 450 ta is it worth it
