The fuse link is available at NAPA etc. It usually comes with some form of connector on each end. Purchase connectors that match when buying one. THey can be out in the open, (best) allowing it to be serviced when needed. All modern electrical systems have fuse links to prevent (most) fires. A welding supply house (especially one that repairs welders) will have cables 0ga that can be cut and soldered into the terminal ends to connect it to the Honkin SW. Routing is cable ties (or metal clips with rubber grommets in them) to solid structures, behind the battery box. Do not use the battery terminals that are clamped or bolted to the end of the cable. Solder on type are best. Good luck, I had to go sledding with my 15 year old for a couple of hours (Toboggan and Ski sleds) JimN
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
