Re: farmall push pull switch
Posted by leroy in ne on March 23, 2008 at 18:39:17 from (67.63.106.62):
In Reply to: farmall push pull switch posted by D Parten on March 23, 2008 at 18:26:53:
one terminal magneto switch is a grounding switch. it stops the engine by shorting the mag. to ground. two terminal switch is for battery ignition. it switches battery voltage to ignition coil, a two terminal switch can be used on mag ignition by wiring one terminal to ground and the other to magneto, however a mag switch with one terminal can never be used with battery ignition.
