assuming you now have a belly pump, you need an open center two way valve, hoses and a pipe tee. take one of the outputs for the belly pump, i like the one on the rt side of the tractor, plumb it to the "in" on your two way valve, from the return on the valve , pipe that to the drain hole on the bottom of the belly pump, i use a tee, so i can still have a drain plug. then route your two hoses from the valve to your cylinder. the control rod on the belly pump must be wired back to the full on position, and then your control valves will operate. the system only works with the clutch out as the belly pump is not a live pump.
Today's Featured Article - A Belt Pulley? Really Doing Something? - by Chris Pratt. Belt Pulleys! Most of us conjure up a picture of a massive thresher with a wide belt lazily arching to a tractor 35 feet away throwing a cloud of dust, straw and grain, and while nostalgic, not too practical a method of using our tractors. While this may have been the bread and butter of the belt work in the past (since this is what made the money on many farms), the smaller tasks may have been and still can be its real claim to fame. The thresher would bring in the harvest (and income) once a y
... [Read Article]
Latest Ad:
[More Ads]
