The 2 prong switch is used on tractors with a distributor ignition, a Magneto uses a 1 prong switch that grounds the magneto terminal when you push in the switch which stops the engine. You can use a 2 prong switch on a magneto if you take one terminal and wire it to ground, but you need to pull out the switch to stop the engine and push it in to run the engine. If you want your restoration to be original, use a 2 prong switch on a distributor ignition or a 1 prong switch on a magneto ignition.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
