Re: 1466 Hydraulic Low Pressure
Posted by Charles Todd on March 23, 2008 at 19:29:28 from (205.242.95.132):
In Reply to: Re: 1466 Hydraulic Low Pressure posted by Allan In NE on March 23, 2008 at 08:55:43:
Allan, would this apply to most or all of the IH and Farmalls with the hydraulic pump bolted onto the side of the tractor (ie: Farmall 504). My 504 has to have the throttle gapped pretty good to make my loader raise, lowers fine. The other valve will roll the bucket both directions at fair idle. I have the hydraulic valves tore down on my bench right now, I did not try switching hoses first (dumb).
On one valve I found the un-latching piston frozen in place and the detent balls pitted. Also the detent balls spring is broken and the centering spring actuator is rusted and pitted. Searching CNH Parts right now.
I bought 2 used valves off Ebay for $230 shipped. I hope I can make two good ones and have a spare. I have enough o-rings for 4. I am going to make a new post...
Thanks
