Posted by Charles Todd on March 23, 2008 at 19:39:42 from (205.242.95.132):
Allan, read your post and saw the pictures of the pump. Would this apply to most or all of the IH and Farmalls with the hydraulic pump bolted onto the side of the tractor (ie: Farmall 504). My 504 has to have the throttle gapped pretty good to make my loader raise, lowers fine. The other valve will roll the bucket both directions at fair idle. I have the hydraulic valves tore down on my bench right now, I did not try switching hoses first (dumb).
On one valve I found the un-latching piston frozen in place and the detent balls pitted. Also the detent balls spring is broken and the centering spring actuator is rusted and pitted. Searching CNH Parts right now.
I bought 2 used valves off Ebay for $230 shipped. I hope I can make two good ones and have a spare. I have enough o-rings for 4. I found a place that has the 376385R95 valve, remanufactured, $425 ea!
The same site also has a power beyond end cap for $250. To add dedicated loader remotes, without splicing into my supply and return, I have an idea. Since I have two end plates (one to modify) can I make a power beyond plate? The end plate has o-rings just like the valves. Can I mill/drill through the center of the o-ring groove and tap to accept ORB fittings and use this to power a loader valve or a 3-spool valve bank? Just a thought.
I can take pictures of the end plate if anyone has further help with this matter before I modify a perfectly good end plate (they are pricey, even used).
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
