Re: Oil in H Distributor
Posted by mdp on March 24, 2008 at 08:49:00 from (24.154.203.226):
In Reply to: Re: Oil in H Distributor posted by DCW on March 23, 2008 at 06:15:47:
my h had same problem several years ago, i just throughly cleaned distributor w/brake cleaner and compressed air, then cleaned out old grease from distributor drive housing (had turned solid & oil in dist was seperated grease, was clear, not engine oil) repacked housing and life was good.
there is a o'ring, current ih part no 272344 that can be replaced, but you still need to service grease in drive housing. there is also a seal in the adapter housing part no 3983231R91 that will keep engine oil from entering drive housing
mdp
