Re: HELP Bubbles around injectors
Posted by FromJB2 on March 24, 2008 at 16:25:02 from (99.241.179.24):
In Reply to: HELP Bubbles around injectors posted by Michael price on March 24, 2008 at 13:32:26:
Michael, it has been 20 years since I had an injector out of a D179 but I recall having to clean out the hole with a battery terminal brush and compressed air, then cranked engine with hole open to blow all the bits out of cylinder.
I believe there was a copper "O" ring on the nozzle. Looked on CIH parts and it shows:
717203R1 O-RING O-RING, injection nozzle sealing.
The time that I had the 2 injectors out, I didn't have replacement "O" rings so just cleaned up old ones and re-used then. Install injector, tighten finger tight then tighten each nut 1/4 turn at a time until tight. Must keep injector in alignment. Use soapy water to check for leaks. Re-tighten after engine has been up to operating temp.
I looked in my I&T manual for 684, D239 but same setup as D179 and the instructions for reinstall is clean hole & torque nuts to 18 ft-lbs. They do caution to drain coolant incase the injector nozzle sleeve comes out and allows coolant into cylinder.
JimB
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
