Re: Oil caps on F-20 Valve cover
Posted by LenNH on March 25, 2008 at 06:29:07 from (65.96.146.183):
In Reply to: Oil caps on F-20 Valve cover posted by VA Gasman on March 25, 2008 at 05:08:06:
The operator"s manual says, "One-sixth of oil can as furnished with tractor." Doesn"t say how big the can is, but you can imagine a typical oil can from the 30s. Total capacity might be a pint? There are two troughs under the rocker cover, each with two felts that absorb the oil poured in, then let it drip slowly over the rocker shafts and down to the valves. Used on all tractors with this type engine until 1939 model change. Pretty primitive, but it worked if the driver just put some oil in there every day.
Use same oil as engine, because it will eventually drip down into crankcase. When I used these tractors, I oiled generously twice a day. Takes just a few seconds.
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
