Farmall Tractors Discussion Board
Re: 706 reverse gear
Posted by Randy B on December 16, 1998 at 20:06:34:
In Reply to: 706 reverse gear posted by Dan Mcfatridge on December 08, 1998 at 12:32:19:
I've been an IH mechanic for 30yrs. and the problem is because there is just to many parts to wear out on the shift linkage. One particular place to look for the problem is the lower arm on the verticle shaft (steering column), it is designed like a clamp with a 5/16 bolt and a woodruff key. This is probably slipping, try tightening or welding making sure it is in the proper position first, then adjust linkage. Many of these parts are available from replacement vendors. Good luck!
Post a Followup
: Re: Re: 706 reverse gear
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
