Re: Oil caps on F-20 Valve cover
Posted by Andy Motteberg on March 25, 2008 at 13:14:33 from (4.143.221.92):
In Reply to: Oil caps on F-20 Valve cover posted by VA Gasman on March 25, 2008 at 05:08:06:
Use the same oil as you do in the crankcase. You need to put oil in those cups to lubricate the rocker arms. F-20's don't have a oil line to feed oil to the rockers, so you need to oil them in the cups daily. There are small trays on top the rocker arms with felt strips that will lube the rocker arms when you pour the oil in the cups.
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
