Re: 666 intrnational
Posted by LenND on March 25, 2008 at 13:59:57 from (216.221.96.202):
In Reply to: 666 intrnational posted by sakara on March 25, 2008 at 13:42:03:
If the 666 is like the 656 your problem is under the seat. The linkage starts at the shifting column and goes down and over to under the seat. What happens is the shifting piston shafts get corroded or dirty and won't let you slide the shifter side ways. You can try to put some WD40 or such on them and try working them loose. If that don.t work then off comes the whole seat and it's time to take things apart and clean or replace stuff.
