Re: Oil caps on F-20 Valve cover
Posted by dan carey on March 25, 2008 at 14:17:42 from (205.188.116.73):
In Reply to: Oil caps on F-20 Valve cover posted by VA Gasman on March 25, 2008 at 05:08:06:
well if i remember correctly there are 3 oil check levels on oil pan!!! from oiling valve levers every day oil pan would overfill !!! if tractor didnt burn oil!! drain oil down to middle,or large petcock!! correct level!! if oil dosent run out of bottom petcock,fill untill it runs out of middle petcock!! keep valve levers oiled as instructions say!! important dan carey you can run a oil line to valves if u r interested in doing it ask me and i will tell u howi did it!!
Today's Featured Article - Fire in the Field A hay fire is no laughing matter-well, maybe one was! And a good life-lesson, too. Following World War II many farm boys returned home both older and wiser. One such man was my employer the summer I was sixteen. He was a farmer by birth and a farmer by choice, and like many returning soldiers, he was our silent hero: without medals or decorations, but with a certain ability to survive. It was on his farm that I learned to use the combination hand clutch and brake on a John D ... [Read Article]
