Re: 50% on tires
Posted by Janicholson on March 25, 2008 at 15:28:54 from (199.17.6.122):
In Reply to: Re: 50% on tires posted by Pat-CT on March 25, 2008 at 14:38:24:
If it is a user tractor, holding air, and tractionare allthat matters. If the tires slip under load more than 10 to 12% Count rotations, check circumference, and distance traveled pulling tillage equip. and compare to find slip %. If weight, and draft control (not on an H) are good, and slippage is more than 12%, I would consider replacement. If it is a light duty wagon hauler, run them till air shows. If it is a show tractor they look best with fairly new tires. JimN
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
