Re: Positive or negative ground
Posted by Dave_Id on March 25, 2008 at 17:02:40 from (70.112.233.145):
In Reply to: Positive or negative ground posted by andy r on March 25, 2008 at 16:43:09:
Normally if the tractor is converted to 12 volt, then you would use negative ground, 6 volt system stays positive ground. Yes, if you switch over to negative ground the wires on the amp gauge need to be switched.
