Re: Farmall A Final Drive Level Check Plug??
Posted by ScottyHOMEy on March 25, 2008 at 17:02:55 from (71.241.213.254):
In Reply to: Re: Farmall A Final Drive Level Check Plug?? posted by Larry Ed on March 25, 2008 at 16:53:04:
Well, that would likely explain how the bugs got in there, too. In my neighborhood, though, the mud daubers woulda had them holes filled and sealed tight!
I use my own web site to link to pictures, so I'm not sure how the others do it. Has something to do with posting it to one of the photo galleries on the left and then linking to that page.
If you want, email it to me at staylor48 at verizon dot net, and I'll put it up so the others can see it, as well.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
