Re: Farmall A Final Drive Level Check Plug??
Posted by gene bender on March 26, 2008 at 05:37:23 from (67.55.226.69):
In Reply to: Re: Farmall A Final Drive Level Check Plug?? posted by Patrick Martin on March 25, 2008 at 16:24:32:
thats not a weep hole there is a locating dowell in that hole. The transmission lube does not get over there but lube from the final drive could.
