Re: Is smoke normal on new engine?
Posted by Steven f/AZ on March 26, 2008 at 15:31:01 from (216.67.213.217):
In Reply to: Is smoke normal on new engine? posted by Michael price on March 26, 2008 at 14:42:48:
White smoke has a couple of causes -
1. It may be cold outside and your exhaust is warm enough that it can be seen as white smoke.
2. Condensation (high humidity) burning off inside the cylinders/manifolds, etc.
3. A coolant leak, allowing water into the combustion chamber or manifolds will also cause white smoke.
4. I also believe that improper injector timing on a diesel can result in white smoke (I think if the timing is retarded). Someone will correct me if I'm wrong on this one.
