Posted by Janicholson on March 26, 2008 at 16:20:10 from (66.173.50.87):
In Reply to: coolant in oil posted by Tinman MN on March 26, 2008 at 15:46:14:
There ar many possible issues: 1} The block may be cracked behind a sleeve. allowing coolant to seep into the crankcase 2) the core plugs in the front could be rusted out allowing coolant into pan 3} The head could be leaking but not obvious (have it pressure checked) 4} The head gasket could be bad, but not easily seen (how long did it sit before you got it,could be a tiny leak) 5} cracked block other than at the sleeves 6} Corrosion in casting under sleeves
Pull the pan and fill the block with water and food coloring (enough to be clearly contrasting the inside of the crankcase) and watch for drops (put clean paper down under it if it is a slow leak. Hope it was a gasket!! JimN
Today's Featured Article - Fire in the Field A hay fire is no laughing matter-well, maybe one was! And a good life-lesson, too. Following World War II many farm boys returned home both older and wiser. One such man was my employer the summer I was sixteen. He was a farmer by birth and a farmer by choice, and like many returning soldiers, he was our silent hero: without medals or decorations, but with a certain ability to survive. It was on his farm that I learned to use the combination hand clutch and brake on a John D
... [Read Article]
Latest Ad:
[More Ads]
