Re: Is smoke normal on new engine?
Posted by K.B.-826 on March 26, 2008 at 16:29:08 from (24.180.154.16):
In Reply to: Is smoke normal on new engine? posted by Michael price on March 26, 2008 at 14:42:48:
Run it for several hours, then let it sit overnight. Crack the oil pan drain plug. If it's getting coolant into a cylinder, some of it should find it's way into the oil. After sitting overnight, any little drop of coolant will have settled to the bottom and be easily visible. The other possibilty is low compression. Are you positive you got the correct pistons?
