Which Batteries To Use in 756 Diesel?
Posted by migraine on March 26, 2008 at 20:27:57 from (67.182.151.248):
Have a 756 Diesel with 4300 hours that I am second owner of and currently has two 6 volt batteries hooked in parallel. This baby does not start good even with hot charge and fuel shut off set in prime position. I thought that these came with 12 volt batteries hooked in series from the factory but I was wrong once before so..... What are you guys going with on these series tractors? Will 24 volts for starting purposes hurt anything electrical on the tractor? It just does not seem to spin the motor fast enough when it is cold even though it is always stored inside.Thanks Migraine
