Re: H drawbar clevis question
Posted by Janicholson on March 27, 2008 at 05:56:03 from (199.17.6.122):
In Reply to: H drawbar clevis question posted by Mike CA on March 26, 2008 at 21:05:25:
The info below is correct, the large pin you have is incorrect. The part is a true cylinder, no bulges or holes in it. The drawbar is placed into the clevis from the back, and the pin is pushed up into the hole (dry) the small tab with hole is lined up with the threaded hole in the clevis so that its longer end is over the big pin hole, and the 1" long bolt is threaded in, holding the small retainer in place. JimN
