The injector that is blowing bubbles might also be allowing coolant into the cylinder. There is a brass sleeve pressed into the head that seals the coolant from the combustion chamber. It is sealed at the bottom by the injector. If there is dirt under the injector it will keep the injector from applying equal pressure all around the bottom where it seals. The same spots that allow the bubbles to come out may also allow the coolant in. Make sure you get the bubbles repaired before using this engine.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
