Re: H drawbar clevis question
Posted by RustyFarmall on March 27, 2008 at 08:12:35 from (209.152.78.71):
In Reply to: Re: H drawbar clevis question posted by Mike CA on March 27, 2008 at 07:28:23:
Mike, for what it's worth, that swinging drawbar was an option. It did not come on the tractor from the factory. If you don't want to spend the money to make everything correct, the drawbar is one place where you can do it. Just remove the drawbar and also remove the bracket that it mounts in. Your H will then be correct, just as it came from the factory.
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
