Re: Use of fuel additives in old tractors
Posted by rust collector on March 27, 2008 at 13:07:02 from (130.18.53.203):
In Reply to: Use of fuel additives in old tractors posted by Gale Roberts on March 27, 2008 at 12:10:38:
Better to use a fuel stabilizer than worry about lead additives. Today's gasoline goes stale much faster and will varnish the carburator if let set. Turn the fuel off and run the carb. dry before shutting down helps. Varnish also deposits in the tank and lines. While I would use a lead additive if I were pulling the tractor at 90+% load for days or weeks at a time, most do not use the older tractors as hard or long enough to justify the need. The lead was a lubricant for the valves and perhaps kept them cooler in heavy load conditions.
