Re: Battery cable question
Posted by Pete in Holland, MI on March 28, 2008 at 09:16:32 from (198.36.89.8):
In Reply to: Battery cable question posted by Mike CA on March 27, 2008 at 17:55:14:
Facts:
1) 6 volt systems require larger cables than 12 volt to get an adequate amount of current thru.
2) Larger cables cost more money.
3) Cable terminal and mounting surfaces do require maintenance from time to time to in sure they stay clean and create little resistanc.
4) 6 volt systems will work on 2, 4 & 6 gauge cables, but less efficently, and endanger your starter.
5) Starting engines in the colder months require more current. If your tractor only runs in the summer months, you can use smaller cables. If you require it to fire up in the dead of winter, you will need larger cables.
