Re: farmall 300 coil wiring
Posted by Janicholson on March 28, 2008 at 20:33:04 from (66.173.50.107):
In Reply to: farmall 300 coil wiring posted by derik on March 28, 2008 at 15:47:32:
If 6v positive ground, the positive goes to the distributor.
If 12v gen with pos ground it is the same, pos to dist.
If 12v with neg ground alternator, it is negative to Distributor.
If repolarized for neg ground, and is still 6v, it is neg to distributor.
If 12v, and it says it needs a ballast resistor, that goes on the key side of the coil. If it is true 12v coil (no ballast required), none needed. Let us know. JimN
