Re: F-12 fuel pump source!
Posted by Bob Kerr on March 28, 2008 at 20:52:26 from (205.188.116.73):
In Reply to: Re: F-12 fuel pump source! posted by John M on March 28, 2008 at 18:33:26:
Yes, this AC pump I am talking about has the sediment bowl! I will rephase the year spread and say 1929-1936. It looks identical to the F-12 pump with the only possible difference being the pump arm which can be changed out (I am not totally sure if the arm is different but suspect it is). Gary Wallace at 20schevyparts.com has the diaphrams and rebuild kits supposedly for modern fuel, but not sure if it will hold up to "reformulated" gas like sold in St Louis, Chicago, California ect. He does live in St Louis so maybe it will.
