Re: F20 OIL CHANGE
Posted by Bob Kerr on March 28, 2008 at 21:05:52 from (205.188.116.73):
In Reply to: F20 OIL CHANGE posted by RODGEinIL on March 28, 2008 at 19:52:23:
Not sure on 35 F-20, but they did have 3 different oil filters on 10-20s. The first type was felt covered cloth and wire spring, washable. second type was metal washable, third type was paper replaceable. I can say all three had different rods and or adapters in the base that held the canister down. Most if used late in years had the paper type installed. I heard from an old timer, IH sold a retrofit kit for them. You may have to pull the filter out and see what you got in there. If you have the cloth type, you will never find a replacement unless you make one. As for oil I use straight 30wt detergent oil in summer. I use that in all my tractors from the 35 F-12 to the 51 H.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
