Re: final drive housing repairs
Posted by Dave S. on March 29, 2008 at 07:07:21 from (208.20.205.142):
In Reply to: Re: final drive housing repairs posted by Allan In NE on March 29, 2008 at 06:33:00:
If you reverse the bull gears the pinion gears should also be switched sides to give a new wear surface.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
