Posted by LN on March 29, 2008 at 07:16:53 from (66.133.174.249):
In Reply to: Welding cast iron posted by STEWARTINPA on March 29, 2008 at 02:06:23:
another option on flat surfaces with cracks is to( dry stitch) them any good machine shop can do this or sell you the kit to do it . To do this you drill holes in the crack, tap it out then wind the special cast iron stitch plug in, drill another hole repeat process over and over till crack is repaired then peen the plugs to have a repair that will hold forever without the heat of welding have had good success doing this with several cylinder blocks and a couple of heads may work with your pan
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
